Sujet : Vidéo: Exact pipe ut 360E
16/10/2015 19:29:04
[*]This saw is ideal for cutting pipes due to its dual speed capability, automatic overload protection and torque control. It works through the material quickly and efficiently even on the hardest cast iron pipe. It is also suitable for cutting plastic pipes because it can cut easily through very thick pipe walls. The PipeCut 360E can also be attached to a shop vacuum to reduce clean-up timeIncludes: PipeCut Bag,Exact PipeCut 360E pipe saw,Pipe Support 360 Double and 2x 360 Single, Operating instructions,Hex socket key 5 mm and 2 mm fitted to the machine,TCT 165 blade fitted to the machine, DVD video disc including instructions
17/10/2015 13:47:37
c'est une idée géniale cette machine qui coupe un tube comme ca
a+
yanko
22/04/2020 08:15:30
Regal38
11/11/2013 20:29:21
Affichages : 3305
02/09/2012 07:23:52
Affichages : 3235
12/12/2016 17:20:16
Affichages : 2748
22/04/2019 21:37:17
Affichages : 5654
13/09/2016 18:11:24
Affichages : 5211
Paulo1974
01/04/2018 17:30:24
Affichages : 2350
Moi37
19/11/2018 20:54:19
Affichages : 3955
26/03/2017 22:53:05
Affichages : 3562
15/08/2012 15:42:01
Affichages : 1896
27/01/2013 15:07:51
Affichages : 5672
nico316l
22/06/2023 19:25:51
Sans Suite Soudure test
09/12/2018 16:52:06 - dany 62
Affichages : 1344
10/12/2018 17:19:59
Affichages : 5213
22/07/2012 09:50:54
Affichages : 1209
12/08/2014 12:05:35
Affichages : 2160
24/08/2014 19:12:29
Affichages : 2557
03/05/2013 10:20:08
Affichages : 4370
06/02/2013 17:25:45
Affichages : 5498
28/10/2016 19:04:58
22/11/2017 16:45:27
