Sujet : Vidéo: Soudage de l'aluminium en TIG en DC sous hélium
01/10/2015 04:35:46
[*]What you will learn in this episode:In this episode of TIG Time we look at the lost art of DCEN (DC negative) Aluminum welding. Many people think that the only way to weld Aluminum is to get a machine that has AC...WRONG! In fact, when trying to get x-ray quality welds on Aluminum, it is actually preferred to weld it on DC - with 100% Helium gas.View more TIG Welding Videos from Weld.com: http://www.weld.com/index.php/Mr-Tig-...Subscribe on YouTube and Never Miss a Video! http://www.youtube.com/channel/UCM0kH...Visit the Welding Forum to Continue the Conversation and Compete in Monthly Contests!http://www.weld.com/index.php/Weekend...Facebook: https://www.facebook.com/WeldDotComTwitter: https://twitter.com/WeldDotCom----------------------------------------­-------------------------------------Weld.com welding videos are a series of welding shows that are loaded with welding tips, tricks and hints that will help you drop that perfect bead every time! Whether you are trying to become better in the areas of TIG Welding, MIG Welding, Stick Welding or Cutting; Weld.com has what you need. All videos are shot from "behind the hood" so you can get the welders perspective. In addition to showing you how to weld, many times we will show you common mistakes and how to avoid them. New episodes every Friday!Early release on the forum!
Belgian diver En ligne le 23/07/2019 à 14:59 (5 messages sur soudeurs.com)
21/03/2016 19:26:36
erreur
21/03/2016 20:22:04
L'aspect est médiocre et la pénétration n'est pas visible sur la vidéo, le support envers en céramique doit éviter que le bain se casse la figure.
Support céramique + hélium.......... l'addition est salée.
Le seul intérêt de cette vidéo est de montrer qu'il est possible de souder l'aluminium avec un poste DC, celà ne vaut pas un bon TIG AC.
21/03/2016 20:28:53
re
même impression que yanng22
l aspect n est pas des plus joli:(
22/03/2016 20:00:23
cela a même l'air un peu bouseux, quant à l'hélium cher mais en plus son prix va s'envoler, car il provient de gisements souterrains qui sont en train de s'épuiser
http://www.pourlascience.fr/ewb_pages/a/article-helium-la-penurie-menace-30412.php
23/03/2016 18:34:45
Bonsoir à tous :)
et oui l hélium est un gaz rare donc très cher
l argon est aussi un gaz rare mais c est le moins rare des gaz rare :D:D
Marinesa En ligne le 06/04/2016 à 10:14 (2 messages sur soudeurs.com)
31/03/2016 09:24:58
Qu'il s'agisse de souder de l'aluminium, cuivre, acier, zinc, or, fonte ou plastique chaque métal nécessite un mode de soudure selon sa structure et selon l'épaisseur des pièces à souder.housse gel sony xperia z5 compact housse xperia z5 compact discount
yanko
22/04/2020 08:15:30
Regal38
11/11/2013 20:29:21
Affichages : 3305
02/09/2012 07:23:52
Affichages : 3235
12/12/2016 17:20:16
Affichages : 2748
22/04/2019 21:37:17
Affichages : 5654
13/09/2016 18:11:24
Affichages : 5211
Paulo1974
01/04/2018 17:30:24
Affichages : 2350
Moi37
19/11/2018 20:54:19
Affichages : 3955
26/03/2017 22:53:05
Affichages : 3562
15/08/2012 15:42:01
Affichages : 1896
27/01/2013 15:07:51
Affichages : 5672
nico316l
22/06/2023 19:25:51
Sans Suite Soudure test
09/12/2018 16:52:06 - dany 62
Affichages : 1344
10/12/2018 17:19:59
Affichages : 5213
22/07/2012 09:50:54
Affichages : 1209
12/08/2014 12:05:35
Affichages : 2160
24/08/2014 19:12:29
Affichages : 2557
03/05/2013 10:20:08
Affichages : 4370
06/02/2013 17:25:45
Affichages : 5498
28/10/2016 19:04:58
22/11/2017 16:45:27
