Hello,
Is there any electric schema (wiring) for rectangular conector on Fronius Magic Wave 2000 Fuzzy?
I know there are 5 wires in torch and connector has 9 pins. Torch has 2 buttons. Two positions pear button.
I put manual for my Fronius here.
Thanks!
I would also need help for remote control connector pins meaning. I put attactment in post with electric scheme.
If somenone can help I would appreciate it. Thanks!
Hi !
Someone asked the same question here : Magic Wave 2000 fuzzy
Perhaps the answer could be useful for you.
This document (http://www.soudeurs.com/attachments/recherche-manuel-de-mode-d-emploi-de-materiel/7697d1376242679-manuel-instructions-magicwave-2200-ac-dc-g-f-manuel-transtig-magicwave.pdf) gives many wiring pictures, may be one is the good one ?
Regards.
Thanks a lot Locouarn!!!
But I didn't find electric schema for magic wavw 2000 ac/dc fuzzy. Thanks anyway!
Best regards!
merci locouarn aucun soucis pour la torche déjà vendue
oui je savais que la connectique n'est pas la même je comptais bien me la faire
je précise d'ailleurs que sur les premiers magic wave, ce n'est pas un connecteur quart de tour mais un 3/8 vissé
Je confirme 5 fils (un neutre et 4 commandes) sur le câble de commande de la torche d'origine ;-)
6 fils utilisés même
le 6ème pour l'identification de la torche selon le schéma
