Sujet : Proposition Lexique des 285 termes de soudage Anglais / Français
04/11/2012 16:23:16
Voici un lexique de termes de soudage tiré du livre : Petit Lexique du Soudage
1. ALLOY
ALLIAGE
2. ANGLE. BEVEL
ANGLE DE CHANFREIN
3. APRON
TABLIER
4. ARC
ARC
5. ARC CUTIING
COUPAGE À L'ARC
6. ARC STRIKING THE
AMORÇAGE DE L'ARC
7. ARC STUD WELDING
SOUDAGE À L'ARC DE GOUJON,
SOUDAGE DE GOUJON
8. ARC WELDING
SOUDAGE À L'ARC
9. BACKFIRE
a) CLAQUAGE
b) CLAQUEMENT
10. BACKHAND WELDING
SOUDAGE À DROITE,
SOUDAGE EN ARRIÈRE
11 . BARE ELECTRODE
ÉLECTRODE NUE
12. BASE METAL
MÉTAL DE BASE
13. BEAD. WELO
CORDON DE SOUDURE
14. BEND(ING) TEST
1. FREE-- -
2. ROOT ---
3 SIDE ---
4. TEE- - -
ESSAI DE PLIAGE
1.--LIBRE
2. --À L'ENVERS
3. _-SUR LE COTE
4.--EN T
15. BEVEL
CHANFREIN
16. BEVEL ANGLE
ANGLE DE CHANFREIN
17. BEVELLING
CHANFREIN AGE
18. BLOWHOLE
SOUFFLURE
19. BLOWPIPE. CUTTING
CHALUMEAU COUPEUR
20. BLOWPIPE. WELDING
CHALUMEAU SOUDEUR,
TORCHE
21. BOTTLE
BOUTEILLE,
BONBONNE (F/CDN)
22. BRASS
CUIVRE JAUNE,
LAITON
23. BRAZE
BRASURE
24. BRAZE-WELDING
SO UDO-BRASAGE
25. BRAZING
BRASAGE,
BRASAGE FORT,
BRASAGE PAR CAPILLARITE
26. BRAZING METAL
MÉTAL D'APPORT
27. BREAK
CASSURE
28. BUCKLING
FLAMBAGE
29. BUILDING-UP (BY WELDING)
RECHARGEMENT DE RECONSTITUTION
30. BUR(R)
BURIN (À METAL)
31 . BURNISHING
POLISSAGE
32. BUTT JOINT
ASSEMBLAGE BOUT À BOUT,
JOINT BOUT À BOUT
33. BUTT WELDING
SOUDAGE BOUT À BOUT,
SOUDAGE EN BOUT
34. CHAMBER. MIXING
CHAMBRE DE MELANGE
35. CHIPPING HAMMER
MARTEAU À PIQUER
36. CLAMP. EARTH.
CLAMP. GROUNO
PRISE DE MASSE,
PRISE DE TERRE
59. EDGE PREPARATION
PRÉPARATION DES BORDS
60. EDGE WELD
SOUDURE SUR TRANCHE
61. ELECTRODE
ÉLECTRODE
62. ELECTRODE, BARE
ÉLECTRODE NUE
63. ELECTRODE. COATED ELECTRODE.COVERED
ÉLECTRODE ENROBÉE
64. ELECTRODE HOLDER
PINCE PORTE-ÉLECTRODE
65. ELECTRODE LEAD
CÂBLE DE SOUDAGE
66. ELECTRODE. METAL
ÉLECTRODE MÉTALLIQUE
67. ENVELOPE. OUTER
PANACHE
68. ETCH TEST
ESSAI PAR ATIAQUE À L'ACIDE
69. FACE SHIELD
ÉCRAN FACIAL,
VISIÈRE
70. FILE
LIME
71. FILLER METAL
MÉTAL D'APPORT
72. FILLER ROD
BAGUETTE D'APPORT, BAGUETTE DE SOUDURE
73. FILLET WELD
SOUDURE D'ANGLE
74. FIXTURE
(APPAREIL DE) MONTAGE, DISPOSITIF DE FIXATION
75. FLAME
1. NEUTRAL-
2. OXIDIZING -
3. PLASMA - . PLASMA JET
4. REDUCING - FLAMME
1. -NEUTRE
2. -OXYDANTE
3. JET DE PLASMA
4. -CARBURANTE, -RÉDUCTRICE
76. FLASH
BAVURE D'ÉTINCELAGE
77. FLASH-BACK
RETOUR DE FLAMME
78. FLASH (-BUTI) WELDING
SOUDAGE (EN BOUT) PAR ÉTINCELAGE
79. FLUORESCENT-PENETRANT TEST
CONTROLE PAR FLUORESCENCE,
EXAMEN FLUOROSCOPIQUE (F/CDN)
80. FLUX
DÉCAPANT, FLUX
81. FOREHAND WELDING
SOUDAGE À GAUCHE, SOUDAGE EN AVANT
82. FORGE WELDING
SOUDAGE À LA FORGE
83. FREE-BEND TEST
ESSAIDE PLIAGE LIBRE
84. FUSION. INCOMPLETE
COLLAGE
85. FUSION WELDING
SOUDAGE PAR FUSION
86. GAS CARBON-ARC WELDING
SOUDAGE A L'ARC AU CAR
87. GAS POCKET
SOUFFLURE
88. GAS PORE
PIQÛRE
89. GAS SHIELDED ARC WELDING
SOUDAGE À L'ARC SOUS GAZ
90. GAS WELDING
SOUDAGE AU CHALUMEAU,
SOUDAGE AU GAZ
91. GA(U)GE. PRESSURE
MANOMÈTRE
92. GENERATOR. WELDING
GÉNÉRATRICE DE SOUDAG
93. GLOVE. WELDING
GANT (DE SOUDEUR)
94. GOGGLES WELDING
LUNETTES DE SOUDEUR
95. GOUG (TO)
GOUGER
96. GOUGING
GOUGEAGE
97. GRIND (TO)
MEULER
98. GRINDING
MEULAGE
99. GRINDING WHEEL
MEULE
100. GROUND
MASSE
101. GROUND CLAMP
PRISE DE MASSE, PRISE DE TERRE
102. GROUNO CONNECTION
MISE À LA MASSE
103. GROUND LEAD
GROUND WIRE
CÂBLE DE MASSE
104. GUN
PISTOLET
105. HAMMER (TO)
MARTELER
106. HAMMER CHIPPING
MARTEAU A PIQUER
107. HAMMERING
MARTELAGE
108. HAND SHIELD
HAND SCREEN
ÉCRAN À MAIN
109. HANDLE
MANCHE
110. HARDNESS TEST
ESSAI DE DURETÉ
111. HEAD
LANCE
112. HELMET
CASQUE
113. HIGH-FREOUENCY WELDING
SOUDAGE À HAUTE FRÉQUENCE
114. HOLDER. ELECTRODE
115. HOLDER. ROD
PORTE-BAGUETTES
116. HOLDER. SOAPSTONE
PORTE-PIERRE DE SAVON
117. HOSE
TUYAU,
BOY AU (F /CON)
118. IMPACT TEST
ESSAI AU CHOC, ESSAI DE CHOC
119. INCLUSION. SLAG
INCLUSION DE LAITIER
120. INCOMPLETE FUSION
COLLAGE
121. INCOMPLETE ROOT PENETR ATION
MANQUE DE PÉNÉTRATION
MANQUE DE TRAVERSÉ
122. INDUCTION WELDING
SOUDAGE PAR INDUCTION
123. INNER CONE
DARD
124. IRON. SOLDERING
FER À SOUDER
125. JET. PLASMA
JET DE PLASMA
126. JIG
127. JOINT (TO)
ASSEMBLER
128. JOINT. (WELDED)
I . BUTI -
2. CORNER -
3. LAP -
4. TEE-
ASSEMBLAGE, JOINT
1.-BOUT A BOUT
2. -EN ANGLE
3. -À RECOUVREMENT
4. -EN T
129. LAP JOINT
ASSEMBLAGE À RECOUVREMENT JOINT À RECOUVREMENT
130. LEAD. EAA TH
CÂBLE DE MASSE
131. LEAD. ELECTRODE
CÂBLE DE SOUDAGE
132. LEAD. GAOUND
LEAD. WORK
CÂBLE DE MASSE
133. LIGHTER
ALLUMORI , BRIQUET
134. LOW PRESSURE TORCH
CHALUMEAU À BASSE PRESSION
135. MACHINE. WELDING
POSTE DE SOUDAGE
136. MAKING A SUIT WELO IN THE HORIZONTAL POSITION
SOUDAGE EN CORNICHE
137. (MANO-) RELIEF VALVE
DÉTENDEUR
MANODÉTENDEUR
138. MELTING POINT
POINT DE FUSION
139. METAL. BASE
MÉTAL DE BASE
140. METAL. BRAZING.
METAL. FILLER
MÉTAL D'APPORT
141. MET AL ELECTRODE
142. MIG-ARC WELDING
(METAL INERT-GAS ARC WELDING)
SOUDAGE À L'ARC MIG (SOUDAGE À L'ARC
EN ATMOSPHÈRE INERTE AVEC ÉLECTRODE FUSIBLE)
143. MITT. WELDING
MOUFLE
MITAINE (F/CDN)
144. MIXING CHAMBER
CHAMBRE DE MÉLANGE
145. NEUTR AL FLAME
FLAMME NEUTRE
146. NON-DESTRUCTIVE TEST
ESSAI NON DESTRUCTIF
147. NOZZLE
BEC, BUSE
148. NOZZLE. CUITING
BUSE DE COUPAGE, TÊTE DE COUPE
149. NUGGET. WELD
NOYAU DE SOUDUR
E150. OUTER ENVELOPE
PANACHE
151. OVERHEAD (WELO)
(SOUDURE) AU PLAFOND
152. OVEAHEAT
SURCHAUFFE
153. OVERLAP
BA VURE, CHEVAUCHEMENT
154. OXIDIZING FLAME
FLAMME OXYDANTE
155. OXY - ACETYLENE CUTIING
OXYCOUPAGE À L'ACÉTYLÈNE
156. OXY-ACETYLENE WELDING
SOUDAGE AU CHALUMEAU, SOUDAGE AUTOGÈNE, SOUDAGE OXYACÉTYLÉNIQUE
157. OXY-PAOPANE CUTTING
OXYCOUPAGE AU PROPANE
158. OXYGEN (-ARC) CUTTING
OXYCOUPAGE
159. OXYGEN-LANCE CUTTING
COUPAGE À LA LANCE À OXYGÈNE
160. PASS
PASSE
161. PEEL TEST
ESSAIDE DÉBOUTONNAGE
162. PEENING
MARTELAGE
163. PENETRATION. INCOMPLETE AOOT
MANQUE DE PÉNÉTRATION,
MANQUE DE TRAVERSÉ
164. PENETRATION. ROOT
PÉNÉTRATION À LA RACINE
165. PERCUSSION WELDING
SOUDAGE PAR PERCUSSION
166. PICKUNG
DÉCAPAGE
167. PLASMA ARC WELDING
SOUDAGE À L'ARC AU PLASMA
168. PLASMA FLAME
PLASMA JET
JET DE PLASMA
169. PLATE
PLAQUE, TÔLE
170. PLUG WELD
SOUDURE EN BOUCHON
171. POCKET,GAS
SOUFFLURE
172. POINT, MELTING
POINT DE FUSION
173. POLARITY. STAAIGHT
POLARITE DIRECTE
174. PORE. GAS
PIQÛRE
175. POSITION OF WELDING
POSITION DE SOUDAGE
176. POSTHEATING
POSTCHAUFFAGE, RECUIT
177. PREHEATING
PRÉCHAUFFAGE
178. PREPARATION. EDGE
179. PRESSURE
PRESSION
180. PRESSURE GA(U)GE
MANOMÈTRE
181. PRESSURE WELDING
SOUDAGE PAR PRESSION
182. PROJECTION WELDING
SOUDAGE PAR BOSSAGES
183. QUENCH TIME
(DURÉE DE) REFROIDISSEME
NT184. AADIOGAAPHIC TEST
CONTROLE RADIOGRAPHIQUE
185. AEACTOR
RÉACTANCE
186. REDUCING FLAME
FLAMME CARBURANTE, FLAMME RÉDUCTRICE
187. REGULATOR
1. SINGLE-STAGE-
2. TWO-STAGE -
DÉTENDEUR, MANODÉTENDEUR
1. DÉTENDEUR À DÉTENTE SIMPLE
2. DÉ!ENDEUR À l'ETENTE DOUBLE,
188. REHEATING OF WELD(S)
RÉCHAUFFAGE
189. REINFOACEMENT OF WELD
SURÉPAISSEUR (D'UNE SOUDURE)
190. AESIDUAL STRESS(ES)
TENSIONS RÉSIDUELLES
191. RESIN
RÉSINE
192. RESISTANCE-BUnWELDING
SOUDAGE EN BOUT PAR RÉSISTANCE
193. RESISTANCE·SEAM WELDING
SOUDAGE PAR RÉSISTANCE À LA MOLETTE
194. RESISTANCE WELDING
SOUDAGE (ÉLECTRIQUE) PAR RÉSISTANCE
195. RESPIRATOR
MASQUE RESPIRATOIRE, RESPIRATEUR
196. ROD. FILLEA.
ROD. WELDING
197. ROD HOLDER
PORTE-BAGUETTES
198. AOOT -BEND TEST
ESSAI DE PLIAGE À L'ENVERS
199. ROOT PENETRATION
PENETRATION À LA RACINE
200. ROSIN
ARCANSON, COLOPHANE
201. SCARF
202. SCARFING
DÉCAlQUAGE
203. SCREEN.HAND
ÉCRAN À MAIN
204. SEAM WELDING
SOUDAGE À LA MOLETTE, SOUDAGE AU GALET, SOUDAGE CONTINU, SOUDAGE ÉLECTRIQUE PAR RECOUVREMENT,
SOUDAGE EN LIGNE CONTINUE
À LA MOLETTE (PAR RECOUVREMENT)
205. SHANK
MANCHE
206. SHIELD. FACE
ÉCRAN FACIAL, VISIÈRE
207. SHIELD. HAND
ÉCRAN A MAIN
208. SIDE-BEND TEST
ESSAI DE PLIAGE SUR LE COTÉ
209. SINGLE-STAGE REGULATOR
DÉTENDEUR A DÉTENTE SIMPLE
210. SLAG
a) LAITIER
b) SCORIE
211. SLAG INCLUSION
212. SOAPSTONE
PIERRE DE SAVON
SAPONITE
213. SOAPSTONE HOLDER
214. SOLDER
MÉTAL D'APPORT
215. SOLDEAING
BRASAGE TENDRE
SOUDAGE TENDRE
216. SOLDEAING IRON
FER A SOUDER
217. SOLDEAING TIP
POINTE DE FER A SOUDER
218. SPATTER
PROJECTION (DE SOUDURE)
219. SPOT WELDER
SOUDEUSE PAR POINTS
220. SPOT WELDING
SOUDAGE PAR POINTS
221. STEATITE
PIERRE DE SAVON
SAPONITE
222. STAAIGHT POLAAITY
POLARITÉ DIRECTE
223. STRESS
CONTRAINTE
TENSION (UNITAIRE)
224. STRESS(ES). RESIDUAL
225. STRIKING THE ARC
AMORÇAGE DE L'ARC
226. STUD
GOUJON
227. STUDDING
ANCRAGE
GOUJON NAGE
228. SURFACING
RECHARGEMENT
229. TACK WELD(ING)
POINTAGE
230. TACK WELDER
POINTEUR
231. TEE-BEND TEST
ESSAI DE PLIAGE EN T
232. TEE JOINT
ASSEMBLAGE EN T
JOINT EN T
233. TENSILE TEST
ESSAI DE TRACTION
234. TEST
1. DESTRUCTIVE -
2. ETCH -
3. FLUORESCENT-PENETRANT -
4. FREE-BEND -
5. HARDNESS -
6.1MPACT -
7 NON-DESTRUCTIVE.
PEEL -
9. RADIOGRAPHIC -
10. ROOT-BEND -
11. SIDE-BEND -
12. TEE-BEND -
13. TENSILE -
14. TIGHTNESS -
15. TREPANNING -
CONTRÔLE
ESSAI
EXAMEN
1. ESSAI DESTRUCTIF
2. ESSAI PAR ATTAQUE À L'ACIDE
3. CONTRÔLE PAR FLUORESCENCE,
4. ESSAI DE PLIAGE LIBRE
5. ESSAI DE DURETÉ
6. ESSAI AU CHOC, ESSAI DE CHOC
7. ESSAI NON DESTRUCTIF
8. ESSAI DE DÉBOUTONNAGE
9. CONTRÔLE RADIOGRAPHIQUE
10. ESSAI DE PLIAGE À L'ENVERS
11. ESSAI DE PLIAGE SUR LE COTÉ
12. ESSAI DE PLIAGE EN T
13. ESSAI DE TRACTION
14. ESSAI D'ÉTANCHÉITÉ
15. TRÉPANAGE
235. TESTING. UL TRASONIC
CONTRÔLE PAR ULTRASONS
236. THERMIT WELDING
SOUDAGE ALUMINOTHERMIQUE
SOUDAGE PAR ALUMINOTHERMIE
237. TIG-ARC WELDING
(IUNGSTEN INERT-GAS ARC WELDING)
SOUDAGE À L'ARC TIG
(SOUDAGE À L'ARC
AVEC ÉLECTRODE DE TUNGSTÈNE)
238. TIGHTNESS TEST
ESSAI D'ÉTANCHÉITÉ
239. TIME. OUENCH
(DURÉE DE) REFROIDISSEMENT
240. TINNING
ÉTAMAGE
241. TIP. CUTTING
BUSE DE COUPAGE,
TÊTE DE COUPE
242. TIP. SOLDERING
POINTE DE FER À SOUDER
243. TIP. WELDING
BEC
BUSE
244. TORCH, CUTTING
CHALUMEAU COUPEUR
245. TORCH, LOW PRESSURE
246. TORCH. WELDING
CHALUMEAU SOUDEUR
TORCHE
247. TRANSFORMER. WELDING
TRANSFORMATEUR DE SOUDAGE
248. TREPANNING TEST
TRÉPANAGE
249. TWO-STAGE REGULA TOR
DÉTENDEUR A DÉTENTE DOUBLE
DÉTENDEUR A DOUBLE DÉTENTE
250. UL TAASONIC TESTING
CONTROLE PAR ULTRASONS
251. UNDEACUT
CANIVEAU
252. UPSET WELDING
SOUDAGE (BOUT À BOUT)
PAR REFOULEMENT
253. VALVE
a) ROBINET-VALVE,
VALVE
b) SOUPAPE
254. VALVE. (MANO·) RELIEF
DÉTENDEUR,
MANODÉTENDEUR
255. WARPING
GAUCHISSEMENT
GONDOLAGE
256. WELD (TO)
SOUDER
257. WELO
SOUDURE
258. WELD BEAD
CORDON DE SOUDURE
259. (WELD) CRACK
CRIQUE
FISSURE
260. WELD. EDGE
SOUDURE SUR TRANCHE
261. WELD. FILLET
SOUDURE D'ANGLE
262. WELD NUGGET
NOYAU DE SOUDURE
263. (WELD). OVEAHEAD
264. WELD. PLUG
SOUDURE EN BOUCHON
265. WELD(S). REHEATING OF
RÉCHAUFFAGE
266. WELO. REINFORCEMENT OF
267. WELDABILITY
SOUDABILITÉ
268. (WELDED) JOINT
ASSEMBLAGE,
JOINT
269. WELDER
a) SOUDEUR
b) SOUDEUSE
270. WELDER. SPOT
SOUDEUSE PAR POINTS
271. WELDEA. TACK
POINTEUR
272. WELDING
1. ARC -
2. ARC STUD-
3. BACKHAND -
4. BRAZE -
5. BUTT-
6. FLASH (-BUTTl-
7. FOREHAND-
8. FORGE -
9. FUSION-
10. GAS -
11. GAS CARBON-ARC-
12. GAS SHIELOED ARC-
13. HIGH-FREOUENCY -
14. INDUCTION -
15. MIG-ARC -
16. OXY-ACETYLENE -
17. PERCUSSION -
18. PLASMA ARC -
19. POSITION OF -
20. PRESSURE -
21. PROJECTION -
22. RESISTANCE -
23. RESIST ANCE-BUTT -
24. RESISTANCE-SEAM -
25. SEAM-
26. SPOT -
27. TACK -
28. THERMIT -
29. TIG-ARC -
30. UPSETSOUDAGE
1. - À L'ARC
2. - À L'ARC DE GOUJON -DE GOUJON
3. -À DROITE, -EN ARRIÈRE
4. SOUDO-BRASAGE
5. -BOUT À BOUT,-EN BOUT
6. -(EN BOUT) PAR ÉTINCELAGE
7. - À GAUCHE,- EN AVANT
8. - À LA FORGE
9. - PAR FUSION
1O. - AU CHALUMEAU, -AU GAZ
11. - À L'ARC AU CARBONE
12. - À L'ARC SOUS GAZ PROTECTEUR
13. - À HAUTE FRÉQUENCE
14. - PAR INDUCTION
15. - À L'ARC MIG
16. - AU CHALUMEAU, -AUTOGÈNE, - OXYACÉTYLÉNIQUE
17. - PAR PERCUSSION
18. - À L'ARC AU PLASMA
19. - POSITION DE
20. - PAR PRESSION
21. - PAR BOSSAGES
22. - (ÉLECTRIQUE) PAR RÉSISTANCE
23. - EN BOUT PAR RÉSISTANCE
24. - PAR RÉSISTANCE À LA MOLETIE
25. - A LA MOLETTE, - AU GALET, -CONTINU, - ÉLECTRIQUE PAR RECOUVREMENT, -EN LIGNE CONTINUE A LA MOLETIE (PAR RECOUVREMENT)
26. - PAR POINTS
27. - POINTAGE
28. - ALUMINOTHERMIQUE, - PAR ALUMINOTHERMIE
29. - À L'ARC TIG
30. - (BOUT A BOUT) PAR REFOULEMENT
273. WELDING BLOWPIPE
CHALUMEAU SOUDEUR,
TORCHE
274. WELDING CONNECTOR
RACCORD (DE CÂBLE DE SOUDAGE)
275. WELDING GENERATOA
GÉNÉRATRICE DE SOUDAGE
276. WELDING GLOVE
GANT (DE SOUDEUR)
277. WELDING GOGGLES
LUNETTES DE SOUDEUR
278. WELDING MACHINE
POSTE DE SOUDAGE
279. WELDING MITI
MOUFLE,
MITAINE (F/CON)
280. WELDING ROD
BAGUETTE D'APPORT,
BAGUETTE DE SOUDURE
281. WELDING TIP
BEC,
BUSE
282. WELDING TORCH
CHALUMEAU SOUDEUR,
TORCHE
283. WELDING TRANSFORMER
284. WHEEL. GRINDING
MEULE
285. WIRE. EARTH
WIAE. GROUND.
WORK LEAD
CÂBLE DE MASSE
Tiré du livre Petit Lexique du Soudage
1974
Office de la langue Française
13/03/2017 10:05:00
Oh merci grandement . J'ai posé la question dans un nouveau sujet que je m'en vais effacer de ce pas !
Questions :
"RÉGIMES DE SOUDAGE" (C'est bien le terme pour les différentes "avances" ( excused me je ne connais presque rien mais regarde des vidéos en americain"
WHIP AND PAUSE ou WHIP AND BEAD
( En français ?)
Zigzags, petits ronds ( en Francais déjà serait bien)
KEY HOLE . ? ( apparaît quand on remplit le FOND (ROOT) de un chanfrein, peut aussi être un defaut si le trou sur ouvre au lieu de se boucher.)
OPEN ROOT ( chanfrein ouvert au fond ?)
STICK WELDING ...( À l'électrode enrobée)
MMA (PAREIL)
WALKING THE CUP
(GODILLE ?)
Si un bilingue pouvait les ajouter , merci.
Je pense ajouter des termes au fur et à mesure.
Certains ne sont certainement pas normalisés, mais plutôt imagés , ces termes la en Francais seraient sympa aussi ( sujet " l'argot du soudage ?)
Exemple "aller à la peche" ( l'électrode colle !)
Amicalement.
Alpha87 En ligne le 03/06/2024 à 02:49 (48 messages sur soudeurs.com)
09/09/2018 10:45:49
Regimes de soudage : travel speed
WHIP AND PAUSE Avancer puis marquer un temps d'arret ou WHIP AND BEAD avancer puis ajouter une goutte de metal d'apport
A welding bead c'est un cordon de soudure mais bead tout seul est considere comme etant le metal d'apport.
Balayer c'est weave : zigzag weaving + circular weaving
chisel : burin
Le key hole ont le trouve que sur un open root (chanfrein a bord ouverts ou espacement entre 2 pieces pour la pene)
Key hole : c'est le trou que tu as en avancant par exemple a l electrode dans ton chanfrein
Walking the cup : C'est le fait de souder son tube en entier en godillant buse posee.
09/09/2018 15:49:04
Envoyé par Alpha87
chisel : burin
Bonjour Alpha87
Merci pour votre intervention
Merci pour les compléments d’informations.
N'hésitez pas à ajouter ici tous les termes que vous connaissez et qui sont utiles à la profession.
Bonne fin de journée
Yann En ligne aujourd'hui à 06h55 (1683 messages sur soudeurs.com)
09/09/2018 17:26:13
Dominique, le copier/coller de ce lexique a engendré pas mal de "fautes de frappes" dans la recopie.
Il est à noter que ce lexique est rédigé par des canadiens et que donc des différences existent entre la langue française parlée au Québec et celle que nous pratiquons ici, de même que des écarts existent entre l'américain et l'anglais.
Affichages : 13012
27/02/2013 20:11:40
Affichages : 13163
09/09/2018 17:26:13
Affichages : 9540
AristideC
30/06/2021 09:34:02
Affichages : 5797
reenot42
01/12/2014 08:49:23
Affichages : 17189
reenot42
20/02/2014 07:47:34
14/12/2012 16:15:59 - rens88
Affichages : 3470
rens88
17/12/2012 17:35:52
Affichages : 6131
01/09/2015 19:25:37
Affichages : 1061
rodwood
18/09/2020 10:43:12
18/03/2016 09:43:34 - 77cr4w6
Affichages : 1709
20/03/2016 22:36:57
05/10/2010 09:07:37 - blego
Affichages : 12072
blego
06/10/2010 06:53:28
Affichages : 5415
20/09/2007 08:23:11
Porte échelle pour remorque
Affichages : 6951
23/11/2010 14:46:20
Affichages : 5322
Ioannis sykopoulos
08/12/2023 22:19:58
Affichages : 6868
christmas9720
26/07/2023 11:51:54
18/10/2016 10:30:20 - jpsoud
Affichages : 3038
jpsoud
24/10/2016 08:11:56
26/03/2013 12:29:29 - ptilou
Affichages : 4824
ptilou
05/04/2013 08:48:38
Exemple de DMOS procédé 111
Affichages : 6252
SARA MESFAR
11/03/2015 10:20:58
Affichages : 496
nhuille
26/02/2019 08:28:57
Affichages : 3451
jeaneugene
12/02/2016 11:15:48
problème soudure cassante
Affichages : 2006
12/05/2012 06:49:44
